RCU Forums - View Single Post - Need Ignition Problem Advice ???
Old 10-03-2009 | 10:11 PM
tkg
Default RE: Need Ignition Problem Advice ???
TCSA timing is 28-30 degrees BTDC at WOT and 4-8 degrees at idle.
Quick and dirty check, AT idle, with the engine at TDC the magnet will be just leaving sensor. Sorta like a figure 8.
Make sure the linkage is going in the correct direction, from idle to WOT the sensor ring moves CW.
