RCU Forums - View Single Post - GP .60 Reactor Bibe
Old 10-03-2009 | 11:44 PM
  #68
malcolmm
Default RE: GP .60 Reactor Bibe
I'm just finishing up my Reactor bipe, using the recommended Rimfire .80 and 3300 6S lipo.
The manual doesn't give much information on servo extensions to the wings. I plan to use the 2 into 1 servo connectors. I will have to remove the wings to transport the plane. Has anyone done a similar setup - what servo extensions should I buy?
Since I have to take take the wings off, I am guessing I will need a servo connector where the servo wire exit the top wing, to plug into something coming up through the fiberglass wing brace. I would guess this would mean a 12" from each top aileron servo, then another 12" from each of these, they would then plug into the 2 into 1.
Ideally I would obviously like to use a single 18" or 24" into the 2 into one. However, threading these servo wires down the brace and past the plywood battery tray would seem to be very difficult at the field.
