RCU Forums - View Single Post - Kadet Senior Bash Pictures
Old 10-04-2009 | 11:36 AM
SeamusG's Avatar
SeamusG
Default RE: Kadet Senior Bash Pictures
Hey AV - nice runway! Talk about a CGnightmare. Kadet Seniors are soooo modifyable. Our club has 1, 2 and 4 motor seniors. They pull gliders and drop candy. They carry cameras. What ever you need it to do.
Can you show a detail of your landing gear? I used a stout wire with standoffs to reinforce the flat aluminum gear. Kinda heavy.
ORIGINAL: Broken Wings
You have a real talent for being able to use different colored/shapes of covering materials. How do you cut your material? Do you remove the backing, cut your peices, seam them together and then apply them to the sturcture?
What tools are you using? What are you cutting the material on? How do you overlap the covering so the seam doesn't come apart when you iron it on the structure?
Silversmiths use various temperature solders to keep thier work from coming apart as they add the spout/handle/base to a tea pot.
Give it up...What's your secret?
With a single light dangling from the ceiling in dark dank basement, sitting on a bar stool without a back, hands tied behind my back, feet tied to the legs of the stool, trying to shake off the affects of sodium pentathol ...
Thx for the kind words BW,
Icut covering with the backing still intact with a new razor blade or, occasionally, a #11 X-acto blade. Ido almost all of my cutting on glass (a mirror and a smaller pane of glass). The mirror is one of the those long mirrors that mount on the back of a door. Pretty light, about 48"long by 12" wide. 60x24 would be great.
For straight cuts I use several rulers - 48" , 24" 12" and 6". All have one side covered with blue painter's tape to protect the covering and grab the covering while cutting straight lines to keep the covering from shifting. Friends use a cutting board like that from Great Planes. I haven't tried it yet. For curves Ihave a decent set of French curves for marking the film top with a thin Sharpie - easily cleaned up with alcohol. Icut the curves freehand with a new blade - not using the curves because they are made of plastic and the razor will cut into them. For all lines I never lift the razor blade until the cut is finished.
If Iam creating a panel made up of several pieces of covering I will remove the backing and then lay the "under" piece down on the mirror. Using a trim iron on low with no sock (Ultracote's adhesive will just activate) I secure about 1/4" of the edge of the covering to the mirror. After it cools the covering is easily removed from the mirror without leaving any adhesive. Ithen remove the backing from the "over" piece and lay it over the "under"edge creating a 1/4" - 3/8" seam. I start in the middle of the seam using a low heat trim iron (no sock) to seal the seam. Make sure that both pieces lay entirely flat. Take it slow and don't stretch anything. Repeat if there are more than 2 pieces that make up the panel. After the seams are completed out comes the standard iron (with a sock) set at a temp that fully activates the adhesive - this will fully activate the adhesive and set all of the seams. Let everything cool and then carefully peal the panel from the glass. You can cover a full wing half with a single multi-color panel. Btw, in my case I violated seam covering rules of "dark over light". The transparent green overlapped silver - oh geez, the seam shows. Ultracote bright yellow is not opaque and the green shows though the seam - well, just sue me.
On this plane the full wing half could have been covered with a single panel, but, because of the size (and fear of messing up a bunch of covering), I decided to use a combination of panels &pieces - using the wing's structure. The top was 1st covered with a piece of silver over the tip because of the stretching needed. The end was wrapped 1/4" over the edge of the 2nd rib and sealed to the side of the rib. A panel of green &the yellow triangle at the center was put together overlapping the silver wing tip cover by 1/4", the main spar, the center "fiberglass" line, and the trailing edge. The full leading edge was covered with a panel of silver and yellow. The bottom was pieced together starting with green that spanned 2 wing bays - it overlaps the tip's silver, the main spar, the rear spar and wrapped around the edge of the 2nd rib. This was repeated with silver, green, silver, green, etc.
Hope this answers your questions. If not, well that's just tough
