RE: Need Ignition Problem Advice ???
I had similar strange running problems on a G23 modified for EI with a Ridge Machine system. Tried a number of things that did nothing to improve the running. Finally, I changed the spark plug and it solved all the problems. Have you tried that? Good luck.
