RCU Forums - View Single Post - Structural Question
Old 10-05-2009 | 11:18 PM
Campgems
Default RE: Structural Question
ORIGINAL: Alex7403
I wouldn't do this.
plywood stands better through stress than balsa.
stress = force / area
means you need much more balsa to stand the same amount of stress as plywood.
who ever designed this airplane didnt choose balsa for a reason.
how many ounces do you think you are gonna win?
while you are risking the whole airplane.
cant you just put a bigger motor?
I dont know the global raven 60
Sound advise. If the sides are warped, build the fuse with the warps fighting each other. It is almost impossible to get absolutely straight wood, be it sticks and sheets or ply. Build so the warps are in oposition to each other to equal a straight build.
I'm working on an older scratch/plans built pattern plane. It has the old school balsa sides, and it weighs a ton, 13 lb actually, I bought it third hand from an ex club member. Icould probably cut the weight down to around 8 or 9 lbs using a lite ply construction vs the balsa sides and bottom.
When you have to cut a window in the side and put a frame to screw a lit ply sheet to to mount your switch to because the balsa sides are to thick for the screws, lite ply construction sounds better and bettter all the time. I'm talking about a GP Super Aeromater that I built a couple years back. A redesign of the kit using Lite Ply would probably give a model of around 6.5 to 7 lbs vs the 9.5Lbs it weighs today.
Build with what you have and build it square and it will be OK.
Don
