RCU Forums - View Single Post - cv 12 mounted on lmh 117
Old 10-06-2009 | 03:42 AM
  #168
lawrencelkl
Default RE: cv 12 mounted on lmh 117
Hi Peter,
Last night when I was taking out the OS MAx 10 from my lmh 100+, I thought of want to give it just another try before drawing conclusion that OS max 10 is not suitable. I have swaped it with another os max 10 which i have bench run with aero propellor and was seems powerful. I suspect that maybe the os 10 max i used before was worn out or something ( air leaks?) and will give it antoehr try with a second os max 10.
all are installed, just wait for a test then...i am also thinking if there is a more efficient way for the cooling...bigger custom made heat sink etc....
good luck!
Cheers
Lawrence
