ORIGINAL: submikester Okay, so it does work with the 9C then (That's what I have). Where can I find the technical information on this (like the manual?). I looked on the Hitec site but was unable to find any specific Futaba compatibility information. My understanding is that things are supposed to be available sometime this month?
Hitec RCD Optima 6, 7 & 9ch Receiver ManualHitec RCD 2.4GHz Spectra Module Manual
No specific instructions relating to any one type of transmitter as the two listed Manuals cover various instalations anduses. Web search will evidence posts already submitted on variousforumsby severalsatisfied Futaba owners describing theirvarious transmitters and resultswith the Hitec 2.4GHz Spectra installed.
The most comprehensive threadon the Hitec 2.4GHz system includes a tip for thosefrequently interchange modules and wish to avoid time taken to interchange PPM&2.4Ghz TX antenna:
Antenna Mount - suggested alternative. Full thread has sufficient information to answer almost any question.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
Post Script: 20Nov09.
Spectra Pro Antenna Mast fitting
Spectra 2.4G is also compatible with other Module Type Transmitters that use the same Futaba/Hitec module shape/size/pin slots. e.g.:
5UAF, 5UAP
7UAF,7UAFS, 7UAP,7UAPS, 7UHF,7UHFS, 7UHP,7UHPS
8UAF, 8UAFS, 8UAP, 8UAPS, 8UHF,8UHFS,8UHP, 8UHPS
<span style="font-size: smaller">(8FGA, 8FGHas non-module radioscan not beaccomodated).</span>
9CA, 9CH, 9CAPS, 9CAFS, 9CHPS, 9CHFS
10CH, 10CA
<span style="font-size: smaller">(10CAG or 10CHG as non-module radioscan not beaccomodated).</span>
</p>
