I ordered 4 Bow Ties and i got only 2, so i was just trying them out. I'm in Suriname and it takes about a month for stuff to arrive here. It isn't always clean, i just finished putting it together after another rebuild. Last time i ran it, it was keeping up with 8ight's, revo's & muggy's.
In the past 6 months i added:
LXBTA4 HPI Gear Differential Bevel Gear 13T/10T
LXFYP5 HPI Slipper Clutch Maintenance Kit
LXGGP7 O.S. 18CV-RX ABC w/11J Rotary Carb
LXM719 HPI Brass Collet w/Washer 7x5mm
LXM725 HPI Clutch Bell 14T
LXM759 HPI Lightweight Flywheel 40mm Pull Start
LXTB43 HPI Differential Case Nitro RS4 MT
LXZT47 HPI Gear Differential Adjustable Spring Set
LXWC13 HPI Nitro MT-1 Racer Truck Body
LXM875 HPI SS Monster Wheel Rear Black D
LXGJU2 HPI Spring 14x80x1.1 14 Coils Purple Nitro MT2
LXN155 HPI Spring Rear Blue/Hard RS4 MT
LXGJU1 HPI Spring 14x80x1.1 15 Coils Blue Nitro MT2
LXXJ60 HPI Spring 12 Coils Super Firm
LXHSR5 HPI Alum Threaded Rear Shock Set 77-117mm RS4 MT2
LXHSR4 HPI Alum Threaded Front Shock Set 70-103mm RS4 MT2
PROC1075 Pro-Line Dirt Works 2.2 Truck
LXTSZ2 HPI Carbon Graphite Gearbox Set
LXJYM2 HPI Heavy-Duty Final Gear Set P1x38T/P1x13T
HPIC7432 HPI Differential Case Nitro RS4 MT
LXJEY9 HPI Heavy Duty Differential Shaft 5x26x7mm Savage
L5DX7802 Pro-Line 2.2 Rear Hole Shot Truck Tire M3 (2)
LXHFL1 HPI Sway Bar Set Nitro MT2 Truck
The aluminum stuff is all GPM that's was already on it.
The track where we race
