RCU Forums - View Single Post - servo compatibility
Old 10-06-2009 | 02:05 PM
Rodney
Default RE: servo compatibility
If you physically modify the Futaba connectors so they will mechanically fit, yes. This usually involves sanding or cutting off the key flange on the Futaba servo connector and then chamfering the corners to match whatever receiver you are using.
