RCU Forums - View Single Post - Dynaflite Butterfly build
Old 10-06-2009 | 11:51 PM
  #78
ejam
Default RE: Dynaflite Butterfly build
Well as of tonight I have completed the covering on the fuse. I have the throttle control rod hooked up, and tail section epoxied.
As I was waiting for the tail to dry, I started installing 1/16th balsa sheet as web braces. I found some 1/32 balsa sheet that Im going to sheet the two outer ribs with. I may even put a sheet on each side of the joining ribs. It depends on how difficult the outers are. Pictures will come soon.
