RCU Forums - View Single Post - Weatronic 2.4 RF diagnostic tool
Old 10-07-2009 | 12:41 PM
  #51
Carsten Groen's Avatar
Carsten Groen
Default RE: Weatronic 2.4 RF diagnostic tool
Hi Oliver,
I mounted a 12 channel micro reciver in a small prop delta plane (an outlaw), if it went down, it would only be a propplane [:'(]
It looks as far as I can see ok, the dropout at the end of the first file is due to landing off-field (around 100 meters from myself, when I walked to get the plane, I placed the transmitter on the ground, and I assume that the TX got no frames back from the plane then. I picked up the plane and walked back to the transmitter, and the signal increases again.
Can you have a look and see if the data looks ok ? (I can send you the data via email if I can have your address ?)
Transmitter is a 14MZ
ID:	1290251   Click image for larger version
