RCU Forums - View Single Post - What type of fuel?
Old 10-07-2009 | 08:03 PM
Mr67Stang's Avatar
Mr67Stang
Default RE: What type of fuel?
The TH .46 is a pretty good engine with a bearing supported crank shaft. I would run 15% in it to mae needle settings a little less finicky and synthetic oil blend. Just my opinion. For busshinged engines you should run fuel with real castor oil in it by the way and higher nitro content can make dificult to tune engines a little easier.
