Como/italian Engine/principles>2-s
OLD BUT BRAND NEW -STRANGE AIR BLEED CARB. HAS A TAPERED
NEEDLE IN BRASS BLOCK BY FUEL INLET.... SHUT-OFF VALVE???
ALSO I WOULD LIKE TO RUN ENGINE BACKWARDS , IT"S A .51CU
TO PUSH A GRAUPNER CHINOOK 80"SPAN SCALE ULTRA-LITE
I HAVE A THREE BLADE 10X6 STANDARD PROP. ANYONE HAVE
INFO ON EITHER SUBJECT? ALSO HOW ABOUT THE CHINOOK.
PS. CARB HAS HIGH JET/LOW AIR-BLEED. THIS STEEL NEEDLE
HAS A 45 DEGREE BEND FOR TURNING WITH A COMPRESSION
HEX NUT TO LOCK IT ..................... .ENGINE I BELIEVE IS SIMILAR TO
A THUNDERTIGER.
