RCU Forums - View Single Post - Weatronic 2.4 RF diagnostic tool
Old 10-07-2009 | 11:59 PM
  #54
Robrow's Avatar
Robrow
Default RE: Weatronic 2.4 RF diagnostic tool
ORIGINAL: David Gladwin
Hi Guys,
Yes, I believe it is the the right antenna looking at the plug side.
I have now installed an 8 Micro into a 5 meter Nimbus sailplane with a Powerbox as there are so many servos in the wing, 4 flap, 4 aileron and 2 airbrakes. With the Powerbox handling 7 channels and one channel direct to the receiver operation looks to be entirely normal, no compatibility problems even with three Matchboxes to distribute the signals. All I need now for flight test is something to tow it up !
The big 12-30 is now installed in the Reaction for flight test, hopefully next week. I will post some log files whan I have done the first few lights. Power supplies chosen are Duralite 4 cell (redundant) 4300 main battery and Duralite 2150 two cell pack all with 16 AWG cables.
Incidentally I bought a Dell Mini computer to take to the fiels for Weatronic use as I do like to look at the data during and after a flying session, Giga Control, Nav View and Rx control all installed.
This computer seems perfect for such use, small light, fast and quite cheap. Strongly recommended.
Keep the info coming !
Regards,
David.
PS Oliver, When binding you ALSO need to press the bind button very shortly after switch on , just pressing the bind button after around 1 minute and the bind function does not work. A guy on the other Weatronics thread could not bind his receiver, pressing the button immediatley after switch on fixed his problem.
Hi David, sorry to go 'off topic' slightly, did you have any joy communicating with Germany regarding the repair of my Tx module and micro Rx?
Rob.
