RE: What type of fuel?
Until the engine is broken in it is going to be hard to tune and may seem to run rough so bear this in mind. For the first half to full gallon you need to verify the needle setting before each flight. After that you should be able to fly several times before any adjustments are needed. But it should be a good habit to verify that the engine is running in tune before the flying day. Your instructions will tell you how.
