RCU Forums - View Single Post - Would this have enough cooling?
Old 10-09-2009 | 05:50 AM
pe reivers
Default RE: Would this have enough cooling?
If you open up the cowl like pictured, and place an airdam at the rear op the cylinder, you create an airflow THROUGH the cowl inssted of OVER the cowl.
Next required step is to make a baffle in the front 1/3rd part of the cooling fins, to force the air THROUGH the fins, instead of AROUND the fins.
