RCU Forums - View Single Post - Spur Gear
Thread: Spur Gear
Old 10-09-2009 | 01:25 PM
RCToysNh
Default RE: Spur Gear
ORIGINAL: delorean123
I see that there is a steel spur gear available for the Volcano S30.......What's the Volcano come with from the factory...??
And is this upgrade an advisable one..??...If so...Why..??
Curious ,,That's all
Yes and no. The Steel set cost 3 times what the stock gear cost. Gear mesh needs to still be set. They will last longer but also may cause damage else where if the gears bind or get debris in the teeth.
Volcano sets:
08033t is the gear set
08013t is the assembled gear set.
On our site if you need them.
