RCU Forums - View Single Post - How do I know when a plane is level?
Old 10-10-2009 | 05:50 PM
Gray Beard
My Feedback: (-1)
Default RE: How do I know when a plane is level?
With kits and plans built planes there is a line going through the fuse on the plans called the datum line, that is the true center for level. Most stabs are set at zero incidence so it's another good spot to put the little bubble level. I have one I use that almost weighs nothing but they can make a bit of difference. You should start with a slightly nose heavy plane anyway so the little added weight shouldn't be any big problem.
