RE: DL100
Jodi, Maybe when I advance the throttle after the initial start, the reason it won't advance is because it's too rich and not too lean. Can you give me a educated guess on how far out the low mixture setting should be....I know a lot of different things come into play but I would think that most ems carbs in a dry climate should be about the same.
