RE: TB-03D Gearing Help
yes you will need a different pinion. spur gear change is unnessacary I also have the TBO3D very nice car and very fast with the correct gearing to find out what pinion you need you need to check the instructions and recommendations on the motor... there is also a site that will work it out for you but i forget it... does anyone know?
