Pull Pull versus pushrod on rudder.
When a cable is pulled, there is no chance of any lost motion due to pushrod flexing. (Assuming you are using good quality no stretch cable). A pushrod is subject to some flexing if not done just right. A good cable set up is lighter, too. Centering should be more accurate as the control surface is pulled back to neutral.
