RCU Forums - View Single Post - Multiplex Mentor
Old 10-11-2009 | 08:31 PM
  #51
rcanduavs
Default RE: Multiplex Mentor
Ok here is the update; we have finished the "build" but during the "phase" out we have discovered a few issues that we have discovered.
- The wing mount screws wouldnt go all the way through due to some CA having fallen into the cavity, therefore the wings weren't seating correctly atop the fuselage. We were able to clean out the CA and get the correct seating.
- We had a problem with the prop and spinner because we didnt see anywhere that suggested boring out inside of the prop, we just had to run some sand paper through it.
- The biggest problem and something that we still have to troubleshoot is the fact that the motor wont work. All of the servos for the control surfaces are working, but nothing for the engine. When turning on the transmitter and then connecting the battery pack, we arent getting the alarm beeps that should be present. Any ideas?
David and the boys.
