RE: Regulate an A123 ECU Battery?
Jet Central strongly discourages the use of a 9.9 volt on the ECU. The resulting damage to the ECU could be very expensive for you.
I use a 6.6 (2C) on the big F-15. I needed the nose weight, so a 4600ma was chosen. I get plenty of reliable starts, even with the new ceramic glow plug. Haven't tried thesmaller 2300ma, but willgive it a tryvery soon.Should work fine.
