RCU Forums - View Single Post - Speed Gems Titanite 15t Motor
Old 10-12-2009 | 08:59 AM
john01374
Default RE: Speed Gems Titanite 15t Motor
general rule of thumb is 2 teeth below the turns of the motor so you where correct thinking you would need a 13T pinion. 19T will burn it up if you run it for any length of time. don't rely on the touch method for measuring motor temps. Get a temp gun and make sure you keep that motor below 180F
