RCU Forums - View Single Post - Wrapping the ignition's battery pack in alum foil ....
Old 10-12-2009 | 12:40 PM
Jezmo's Avatar
Jezmo
Default RE: Wrapping the ignition's battery pack in alum foil ....
If you put a large metal object in contact with a radio source it will act as an antenna unless grounded. When you shield the plug wire, you ground the ends so the RFI is captured and routed back to that ground instead of being transmitted into the surrounding air.
