RCU Forums - View Single Post - DL100
Thread: DL100
Old 10-12-2009 | 08:42 PM
  #46
jedijody's Avatar
jedijody
Default RE: DL100
Well done! I knew you would get it. Only thing I hope you have done is make sure that the peak RPM will drop slightly if you richen the high needle about 1/8 turn. The just over 1 turn setting description is a tiny bit leaner than I normally see but it could be correct in your application, the RPMs are what I would expect though. Time to fly!
