ORIGINAL: ScienceisCool
...I don't fly much inverted because of the fear of nosediving into the ground.
</p>
One mistake that has caused more inverted crashes than anything else is "pulling up" when a pilot gets in trouble. I've done it myself as well. When you are inverted you need to constantly remind yourself "roll out of trouble". You should make it a habit to always exit inverted flight be rolling out. If you make it a habit to use the elevator to exit then when you get in trouble the first instinct will be to pull back on that elevator. train yourself to not do that
Ken</p>
