RCU Forums - View Single Post - Wrapping the ignition's battery pack in alum foil ....
Old 10-13-2009 | 11:38 AM
Jezmo's Avatar
Jezmo
Default RE: Wrapping the ignition's battery pack in alum foil ....
ORIGINAL: w8ye
When shielding, normally just one end is grounded so that RFI does not travel along it's surface from point ''A'' to point ''B''
Yep, normally that works, but sometimes a worm drive clamp is necessary on the plug end along with a bonding (grounding) strap back to the module in order to eliminate the RFI. Been down that path already and it was the ONLY solution that worked. We tried the clamp on the plug boot cap first but the interference finally stopped after the bonding strap was installed from the engine case back to the CDI box. Almost always just bonding one end, like you said, will get-r-done. Take care Jim.
