RE: OS 4stroke engine: Will it run with castor?
My experience is the following.
I have a Thunder Tiger F-75S....the first 5 liters of fuel were 22% Castor oil, 12% Nitro and the rest Methanol.... and ran very good.
I've tried coolpower 5% and the engine didn't like the fuel at all!
I tried another fuel with 15% syntethic oil and 12% nitro and the engine didn't produce as much power as with the castor oil...
The problems you may experience running castor oil on 4 strokes are normally not related to performance, but related to carbon build up on the exhaust valve....you may have to clean it regularly (de-coke).
You don't have to use 20% neither... With about 15% Castor oil you will be fine.
The engine may just run fine without nitro as well...maybe you won't get a very low idle or super clean transition...But I haven't tried my 4 stroke without nitro.... I've run all my 2 strokes always without nitro.
Just give it a try! it won't hurt anything in the engine you plan to buy!
