RE: Spektrum AR500 Problems?
Make sure your throttle amd throttle trim are set as low as possible before you turn on the transmitter. If the esc detects throttle input when powered up it won"t arm. Rebind the receiver with the throttle turned all the way down and the other sticks at neutral. Hope this helps- Oemflyer
