RE: Right Thrust Needed?
Mike, with the Eagle II, and with your question, I would make it up with no thrust offset. Decide for yourself what you need. Notice what happens on take off. Notice the difference in left and right turns under power. Then try it inverted and Decide for yourself. You can always put thrust in it on that plane later if you think you need it.
