RCU Forums - View Single Post - Right Thrust Needed?
Old 10-13-2009 | 09:58 PM
KitBuilder's Avatar
KitBuilder
Default RE: Right Thrust Needed?
OK.. thanks... I will keep the down thrust for now.
This older kit uses a mounting plate with a recess for the engine that sits on hardwood rails to obtain the correct right and down thrust. I assume I can add a lite ply wedge the dimensions of the current vertical firewall that would match the needed downtrhustt and bolt an engine mount to it
