RCU Forums - View Single Post - rustler ball diff upgrade worth $50??
Old 10-13-2009 | 10:03 PM
CarGuy7a
Default RE: rustler ball diff upgrade worth $50??
ORIGINAL: monsterbombs
you can adjust a normal traxxas gear diff with different oils, no?
You can run diff fluid in the stock rustler diff. I've done it for a while now until I got the FLM diff housing.
The only problem is, is the stock diff housing is not sealed, so your diff fluid leaks out and makes a nasty gooey mess all inside the tranny case.
