RCU Forums - View Single Post - Venus II - Adding an adjustable stab worth the effort?
Old 10-14-2009 | 07:18 AM
viva_peru
Default RE: Venus II - Adding an adjustable stab worth the effort?
ARTP47 and CustomPC - Thanks for the advice regarding the glow set-ups. In my case, the plane will be electric, so the battery will weigh even more than a fuel tank. I will keep it in mind when trying to figure out where to put the battery tray.
Ed - The answer is yes. Battery access will be through the canopy very much in the same manner as you did in yours. My power system will be a little different since I will be using an AXI 5320/28 instead of the E-Flite 110. I have not decided on the battery just yet, it will probably be a 8S but I was thinking about going to 10S since I have a few 5S packs. I know that weight could be an issue with the higher count pack. We will see. I tried out my first Rhino's packs and they seem to work well, so buying a new set of batteries for an 8S pack may no longer be an issue.
Thanks for the advice,
Teo
