RE: League RC Velox 58 - build thread
Nice work on your Velox, Bill. I spent this evening glueing in the elevator/stab. Yesterday, did hinges on wings and rudder. The white covering on mine seems to separate, with the clear material pulling away from the colored part of the covering. Had to grind it off with sandpaper to expose balsa for the epoxy to grab. Also, the center section of the stab was a bit too narrow; I cut the covering and left enough so it would be tacked down to the center wood without pulling loose. I cut open the servo holes which allowed me to goop epoxy into the tailcone and ensure a good fix on the stab. Will do a bit more of that tomorrow, then do the hinges on the elevator.
