RE: Silly Engine! Bolts should be tight!
Getting that little bit of stretch is the key to torquing bolts right. If you're worried about them vibrating out, put a dab of paint on the side of the bolt head where it meets the engine. You'll be able to tell at a glance if it is moving.
