ORIGINAL: Archie League
I get hits constantly. I rerouted the antenna and still got interference.
Unfortunately that is not necessarily or even likely to be a problem with the radio itself.
Try changing frequencies, try checking the range with the engine off and on.
If the radio doesn't seem to get hits with the engine off, check your throttle linkage.
Metal linkages will cause RF noise.
