RCU Forums - View Single Post - vxl gearbox durability threshold
Old 10-15-2009 | 03:52 PM
Lilredmachine
Default RE: vxl gearbox durability threshold
Maybe because I run the best part of double the power of what you run, and have found that it is the best setup going.
I sheared the MIPs at the point where the shaft meets the stub axle, they are just too weak. The CVDs are fine for 3s running with a short can motor, for certain. You go more than that and you will wreck them.
