RCU Forums - View Single Post - Nylon Wing Bolts
Old 10-15-2009 | 08:04 PM
ArcticCatRider's Avatar
ArcticCatRider
Default RE: Nylon Wing Bolts
ORIGINAL: wcmorrison
That is interesting. I do know that nylon straps used in construction are checked for condition and have a red stripe embedded in the woven material. When the wear gets to the red stripe the straps are removed from service and cut in half to prevent them from being used elsewhere. But there is no time limit on the life of the nylon straps, just a wear limit. There is not weight check required either, just the wear limits.
So if your nylon bolts are in good condition keep on using them.
Question, do you change out the wooden blocks that the screws go into? Do you recycle the glue joints that hold the piece of wood that has the blind nuts or even the wood threads in some applications? If you cycle out the bolts maybe you should check those out too. Shouldn't you remove the mounting piece and install a new one? Do your replace all the control horns and clevis made of nylon too? Do you replace the nylon fibre glass filled motor mounts?
Think about it.
Cheers,
Chip
I do not change the wooden blocks, or motor mounts, nor do I recycle glue joints. Those are far more substantial than a 1/4" nylon bolt would be. Any wing bolts would certainly "cycle," the question being for how long, thus the thread to see the opinions of others.
And yah...I occasionally change out clevises and control horns...you can't expect the 1/32 " nylon clevis pin to last forever. Preventative maintenance....
