RCU Forums - View Single Post - Eman's Tamiya Stadium Thunder kit build
Old 10-16-2009 | 10:44 AM
Eman77's Avatar
Eman77
Default RE: Eman's Tamiya Stadium Thunder kit build
Here's a shot of the front end, with the body posts on. Also, a shot of the rear as I started to put those posts on.
The back seems weird, since you run a screw through the post, then the shock, then into the chassis. So the rear posts are kind of floating out there, and you'd have to remove them to get the rear shocks off. Wacky...
ID:	1296011   Click image for larger version
