RE: T22 Warrior (Christen Diffusion)
Ouch T22 Warrior, that looks like a 'perte totale' indeed :x too bad ! any idea what caused the radio failure ? Was it on 35Mhz or 2.4Ghz ? I myself fly on 35Mhz pcm and have not have had any failsafes so far (I check them after every flight)
Another question T22 if I may : do you remember what servo's you had in the wings ? In mine are 2x2 futaba S3150 (3.7kg/cm) which I think may be a bit weak.
