RE: Seagull Gee Bee Z
Hi R/C Foolish , Congrates on the maiden , from what you have said it sounds like they have removed the rear bracing leg on the
main gear when they went to the struts ? , if you look back you'll see that I kept that rear brace when I fitted up some after market
struts from unitracks international & think that it is required as you have said ,would like to see a picture of this new set up with the
struts.
I think the old wire gear was easily modified I wonder if the wings you have still have the mounting blocks for the rear brace ?.
Cheers Steff.
