RCU Forums - View Single Post - two basic building questions from a newbie
Old 07-02-2003 | 12:25 PM
cstevec's Avatar
cstevec
Default Doping fiberglass
I use 30 minute epoxy thinned with alcohol to the consistancy of oil based paint to apply fiberglass. It is generally recommended to apply the epoxy glass to bare wood so I am wondering are you going to strip the coating from the wing? If you glue the two wing halves together and liberally coat the dihedral brace (wing joiner) and the socket it fits in you should be fine without the fiberglass tape.
