RCU Forums - View Single Post - F3A Special Pattern Radios
Old 10-17-2009 | 11:43 PM
grotto2's Avatar
grotto2
Default RE: F3A Special Pattern Radios
Bo-
It's possible to make a TK or TP module work in a J radio. It's just a matter of making a small adaptor board between the J input pins and the TK/TP output socket. You can remove the plastic cover from the smaller module, insert into the adaptor board and apply a piece of double-sided tape to the back of the new module. Remove the plastic case from the original module and push the outside half into place-Voila!
