RCU Forums - View Single Post - Need Engine for PC-9
Old 10-18-2009 | 01:21 AM
freeair
Default RE: Need Engine for PC-9
you should get into the fuel tank bay and grind off some plywood from the tank bearers so the tank goes down lower. i can,t remember which way the engine is mounted in the PC-9 but if its inverted or on its side , you can also try mounting it upright, this will raise the carby venturi level to stop engine flooding.
