RCU Forums - View Single Post - Wind 110 trimming
Old 10-18-2009 | 07:41 AM
2Sunny
Default RE: Wind 110 trimming
I was one of the guys that worked on the incidence problem with the Angel 50. I built two planes and corrected the incidence to 0/0 on the second plane, but could not discern any change in flight characteristics between the two setups. In fact when I let a "pro" fly both, he felt that the original unadjusted wing setup may have had a slight edge. All that is to say: Would you consider flying it a few dozen times and then reporting back on how it trims out as is? I'm dyin' to hear more about this plane! Also, do you have any pictures of how far out the elevator is trimmed for level flight?
Joe
[link=http://www.rcuniverse.com/forum/fb.asp?m=8053712]Angel S 50 Incidence Issue post[/link]
ID:	1297351   Click image for larger version
