Rudder
Using the rudder is definitely the right way, as it reduces the risk of the wing stalling as you slow down before landing.
Using the ailerons is a major reason why aircraft that are prone to tip stalling snap into the ground, whereas the rudder is about the last control surface to stall.
David C.
