RE: help
Try cutting a cross into the top head with a dremel cutting wheel then use some penetrating oil let dry then hit it with a little torch available at any Radio shack . let cool then take a screw driver and remove the screw, if all that doesn't work try a easy out drill bit
Rick in Denver
