RCU Forums - View Single Post - ZERO BLADE STRIKE CORE 2.0
Old 10-19-2009 | 02:03 PM
sonat
Default ZERO BLADE STRIKE CORE 2.0
is under re-manufacturing to be more compatible with modified motor
BLUE DELRIN GEAR WILL BE AVAILABLE SOON WITH NEW SPEC
outer shaft gear: dia:35,15mm to max 35.42mm color: blue
inner shaft gear: dia: 35.15mm to 35.42mm, color: blue
ZERO BLADE STRIKE CORE PRESENT DESIGN
WE HAVE MANUFACTURE IT TO BE 100% COMPATIBLE WITH STOCK MOTOR
Our company thinking for all our upgrade design: ( low weight = more flight time )
eliminate blades strike and more crash resistant parts
http://www.flyrcrivesud.com/upgrade_parts3.html
