RE: Making a Solid Nose wheel
try chucking it up in a drill with an axle and spinning it fast and see if you get vibration, i had a solid tire that vibrated bad on the take off roll, replaced it and problem solved, i then cut the tire open and found a large air pocket in the material. now i spin all tires/rims before mounting them on a jet.
